How do I configure thermocouple channel as NRSE on a PXI 6232?
Hi!
I am trying to setup several thermocouple channels on a MXI system with a PXI-6232 card and a CB-37F-HVD terminal block.
The thermocouples are K-types and are wired to a digital readout (signal conditioning and isolated output).  The preferred configuration from the DRO is to use RSE terminals AI* and AIGnd.  I noticed in the grounding signal source diagram, an alternative configuration NRSE uses AI* and AISENSE.  However, there is not AISENSE terminal on the 6232 pinout.  Does this mean that signal source mode is not available for this card?
Kenneth
(3,004 Views)
Hi Kenneth,
As stated on page 31 of the NI 6232/6233 User Manual found here, the NRSE mode is identical to the RSE mode.
David
Digital Multimeters
(2,986 Views)
