I have been trying, un-successfully I may add, to utilize the DAQ Assistant express vi to acquire 2 different types of signals. One is from a type T thermocouple and the other is from a pressure transducer. Both inputs are voltage inputs, but my problem is that if I set the thermocouple channel for a thermocouple(to take advantage of the automatic conversion & settings), I cannot add a straight voltage input for the transducer. It forces me to add another TC channel. I am fairly new to LAbview, and was trying to take advantage of as many express VIs as possible. Can you help? I am using a PXI system with a 6070E terminating into an SCB-68.
