How do I create different types of inputs in the same DAQ assistant express vi?
I have been trying, un-successfully I may add, to utilize the DAQ Assistant express vi to acquire 2 different types of signals. One is from a type T thermocouple and the other is from a pressure transducer. Both inputs are voltage inputs, but my problem is that if I set the thermocouple channel for a thermocouple(to take advantage of the automatic conversion & settings), I cannot add a straight voltage input for the transducer. It forces me to add another TC channel. I am fairly new to LAbview, and was trying to take advantage of as many express VIs as possible. Can you help? I am using a PXI system with a 6070E terminating into an SCB-68.
(3,164 Views)
Hi Sno,
Unfortunately this is not possible with the DAQ Assistant at the moment. You've to programatically create your tasks.
Please review this KB for more informations and an example:
http://digital.ni.com/public.nsf/websearch/89B7218072F1CAF686256DC500722B6E?OpenDocument
Luca
Luca
(3,164 Views)
It looks like this might be possible with a workaround. Here is a link to a knowledge base that might be useful.
How Do I Use Different Types of Global Channels In One Program?
http://digital.ni.com/public.nsf/websearch/3296BA2AEF586B7386256D6D00528E3D?OpenDocument
Ron
(3,164 Views)
Thank you for the input Ron. First thing Monday morning I will give it a try. I hope they fix that limitation in the next batch of express VIs.
Sno
(3,164 Views)
Luca, Thank you for the rapid answer. I used the example code and it works. Still would like to do it with express VIs though.
Sno
(3,164 Views)
