How do I display more digits in a cursor readout?
How do you set the precision on the cursor readouts in an xy graph?  There is no precision control on the cursor property page.
(3,427 Views)
Are you talking about the XY Graph in LabVIEW? You've posted to the DAQ forum.
If it is LabVIEW, then right click on the cursor readout and select Format & Precision. You have to do this on each readout you want to change unless you customize the graph.
(3,420 Views)
Dennis,  I'm in LV8.2 and the right click popup menu doesn't show a format and precision option.  Thanks for your help
(3,407 Views)
Hi deserio,
Dennis is right for versions of LabVIEW leading up to 8.0.This has been documented as a bug.
This was reported to R&D (# 3U8E56RC) for further investigation.
Unfortunately, there is no known workaround for this problem.
Michael K | Applications Engineer | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,391 Views)
