How do I find out the actual acquisition sample rate with C daqmx? (USB-6211)
I have a national instruments NI-USB-6211 device, and I want to make my application support this.
I'm writing in C, using NI-DAQMX functions.
I'm doing continuous analog acquisition.  If I ask for a specific rate, such as 20000 or 20005, etc,
how can I find out the actual rate the board is using? (other than measuring against the computer's
clock).
This seems like a very basic thing to want to know, but I can't seem to find anything in the API for this.
Amish
(3,090 Views)
Not sure what you are asking for. The stated accuracy of the sample clock on your device is 50 ppm of the programmed sample rate with a resolution of 50 ns. Obviously, trying to use the computer's clock ( 1 msec resolution at best) as a comparison would be futile.
(3,077 Views)
Thank you for posting to the NI forums.  You can view your sample clock source and rate by using the NI-DAQmx C timing property functions.  Open to the DAQmx C Reference and select NI-DAQmx C Properties.  There, you will find the Timing Properties; I would recommend using the following two functions to get your timing information.
DAQmxGetSampClkRate
DAQmxGetSampClkSrc
I hope this helps!
Ed W.
(3,062 Views)
