I am using a PCI 6036E with an SCXI-1100 to multiplex trough 25-32 channels with low current signals from a photodiode array. I tried using the DAQ Assistant Express to measure current, but it won't let me do the following (even when I convert it to a standard subVI):
1) Select shunt resistor values greater than 1kOhm. (I am using 100MOhm resistors to get the highest gain possible from the low current photodiodes. I want to be able to programatically adjust the gain depending on the different low intensity light sources).
2) Change the gain selection so I can programatically create an auto range select.
John Feiereisen posted a question "Can I set dynamic gains on an SCXI-1100?" on 11/24/1999 wherein he stat
ed:
"In the past I used a single SCXI-1100 as a 'dumb' mux/amp by passing the OUTPUT and AOREF lines to the front panel connector (jumpers W7 & W8), controlling the SCXI with an MIO-16, and passing the mux'ed output to an A2000 with a BNC cable. I pulled CINs out of some LabVIEW-supplied VIs (v2.2?) to select channel and gain. This setup worked great and allowed me to march through a bunch of transducers and select an appropriate gain for each one. (And allowed much faster acquisition rates than if I did the A/D with the MIO-16.)"
It says that he was able to do what I want to do, but I don't understand how he did it.
Any suggestions or sample code? What is a MIO and a CIN anyways?
