How do I get device information via VBA
I've written a smal Daqmx-Application for Excel in VBA. Is it possible to get device information about the connected Daq-device? I need to know how many channels the device has in order to enable or disable some functionality of my programm.
With kind regards,
Alex
(5,295 Views)
I've found the solution with DAQmxGetDevAIPhysicalChans. One more question How do I have to use the function?
At the moment I tyry the following
Dim tmpStr As String
Dim tmp As Integer
tmp = DAQmxGetDevAIPhysicalChans("Dev1", tmpStr, 0)
But I only get a 79 in tmp and an empty tmpstr. Is the something I have to do first? Is 0 for the buffersize okay? What for do I need the buffersize when I ask for physical chanels? I have a USB 6009 Card
Greatings,
Alex
(5,292 Views)
Hi Alex,
the command DAQmxGetDevAIPhysicalChans can be used to show all available AI channels from the device.
DAQmxGetDevAIPhysicalChans(const char device[], char *data, uInt32 bufferSize);
1.The first parameter of the function is a character array (string-array) where you have to transfer the devicename,e.g. "Dev1"
2. The 2nd one is the output value which is also a character array, this is array shows all AI channels
3. buffer size is an integer value, the number specifies the length of the output value array
char result[20000];
int    size = 50;
DAQmxGetDevAIPhysicalChans("Dev1", result, size);
Please make sure for basic testing that only one Device exist. Otherwise the function won't work, because an arry of devices is transmitted -
if this happes you need a for-loop around the function;
Kind regards,
Rupert Donauer,
NIG AE
(5,261 Views)
Hey Rupert,
Thank you for your reply.
When I use the function, the intellisens says, that the function expects device as a string, result as a string and buffer as an integer. By the way, there is no char in VBA as far as I know. So I do this:
Dim result as String
Dim dummy as Long
dummy = DAQmxGetDevAIPhysicalChans("Dev1", result, 50)
Then the result is "" (empty) and dummy is 79. I'm a bit desperate with this problem. What does 79 mean?
Do you have another idea?
Regards, Alex
(5,256 Views)
Hi Alex,
I carried out the functin in LabWindows CVI ( ANSI C development from NI).
I'm not involed in VBA.
Check if the dummy parameter  is required, in CVI the command:
DAQmxGetDevAIPhysicalChans("Dev1", result, 50);
was allright.
Kind regards,
Rupert
Rupert
(5,248 Views)
