cDAQ69171 + NI9402 detection problem (MAX+labVIEW)
hello !
I use the NI 9402 board to generate a single pulse, with the 9171 chassis.
I received it a few days ago, installed it as specified (driver first etc.), and everything worked pretty good ! I designed a Labview application corresponding to my attempts in an hour, LabVIEW is such an good software 🙂
anyway, today those devices (chassis + usb slot) where not accessible anymore through my application. MAX could find them but not commmunicate with them.
I tried to restart my computer, to disconnect/ reconnect the slot etc... and now I deleted the ni9402 from MAX and I can't add it anymore.
the only difference between today and yesterday is that today I first connected an oscilloscope to the computer (GPIB), but I removed it and it didn't change anything...
I searched in the forum and found some similar issues, but it didn't helped me to solve the problem, which is however quitte common I think.
thanks for help, and i hope my english is understoodable 🙂
(3,783 Views)
Hi zeyol,
Thank you for posting on National Instruments' forum.
Can you make a screenshot of the message occured? Your version of your DAQmx drivers are 9.4?
Romain P.
National Instruments France
(3,764 Views)
thanks for responding
My version of the DAQmx drivers is 9.5.
I attached the screenshot of MAX, it contains a link to this page :
http://digital.ni.com/public.nsf/allkb/EDA23D2970BD16C6862577D70006E3CA
but in my opinion it doesn't correspond to my problem, I don't encounter the behaviour described in this page...
regards
(3,759 Views)
Did you try to download and install the hotfix?
Romain P.
(3,756 Views)
no, because I don't have the admin rights on my computer so it takes a few time, but I'm doing it
(3,754 Views)
okay so it didn't solve the problem
actually I can now comunnicate with the device but the same error appears, I think it's due to the restart of my computer...
it's quitte annoying : sometimes it work, sometimes it doesn't...
but I always get this message shown in the attached file
(3,749 Views)
