How do I read the TDS 210 scope and have it show on Labview
I am using a TDS 210 and I am trying to read the signal from the oscilloscope to labview. I tried using the Getting Started 2.vi option, but this does not work. This vi just resets everything on the TDS 210 and then takes data. All I want is to read the data on the TDS 210 without doing anything to it. How would I accomplish this?
(3,182 Views)
JonnyF
What version of Labview are you using? Depending on what version you are using and what kind of communication you are using, the following link may be helpful.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000066C00000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
If not, please post your code and I will take a look at it.
Russell G.
Applications Engineering
(3,182 Views)
I am using labview version 5.1. I am unfamilar with the program and therefore I am not sure where to start.
(3,182 Views)
JonnyF
The NI Drivers for the TDS210 are only supported by LabVIEW 6.1 or 7.0, please see this link.
So you have 2 of options.
1. You can upgrade to a newer version of LabVIEW.
2. You can communicate with the scope using NI VISA VI�s.
Russell G.
(3,182 Views)
JonnyF
I have attached a file that will help you get started communicating with your Oscope using VISA's. Hope this helps.
Russell G.
(3,182 Views)
