Addr. of calibration register with PCI-6033E
Hi.
I'm trying to calibrate my PCI-6033E using Linux/Comedi.
According to the "PCI E Series RLPM", page 5-7, the EEPROM
addresses 430 and 431 should give the LSB and MSB values.
The readings are:
eeprom reference lsb=154 msb=204
resulting reference voltage: 4.98684
which does not seem to be correct. The code is reported to work
for the board PCI-6032E.
I'd like to know if the documentation is correct, and if not, where
can I get the corrent information.
Thank you in advance.
Vitor.
(2,805 Views)
Hello Vitor �
It appears you are using the Comedi DAQ drivers to access your DAQ card from Linux. National Instruments does not support Comedi drivers. For support, please visit Comedi�s website.
You can use the following information as a guide for Comedi calibration:
You will use comedi_calibrate to calibrate your card.
Type comedi_calibrate -f /dev/comedi0 to calibrate the board configured as /dev/comedi0.
Note: Not all E series cards supported by Comedi can be calibrated. See the Comedi website for a list of supported cards.
Have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(2,805 Views)
Hello Becky,
thank you for your answer. Yes, I'm using Comedi, but the
PCI-6033E calibration is not supported. I understand that
National Instruments does not support Comedi, but what
I would like to know is why the documented registers are
storing wrong values.
Please refer to this page:
https://cvs.comedi.org/cgi-bin/bugzilla/show_bug.cgi?id=77
especially the final comment from the Comedi developer, at
the bottom of the page. So, my question basically is: was my
board incorrectly calibrated at the factory or is there a mistake
in the provided documentation?
Vitor.
(2,805 Views)
Vitor -
If you are worried about your board being incorrectly calibrated, a free solution is to use DAQmx and Measurement and Automation Explorer on a Windows machine to recalibrate your equipment. You can also return the board to National Instruments for re-calibration.
Becky B.
Becky Linton
Field Engineer
Cell: 248-709-2822
(2,805 Views)
