How do I run 6216 from different VIs one for Voltage Input and the other for Digital Input?
I have two separate programs.  One starts up the 6216 for analog input then reads three channels in a timed loop.
The second VI sets up reading the 16 Digital inputs and reads them in a timed loop.  I can start each one by itself but when I run the other it stops abruptly.
Never mind.  I had to name the timed loops with unique names in the two VIs.   I remember making that mistake a few years ago.
I'll probably make it again in a few years.
(2,887 Views)
Wow, you answered your own question in the same post.  That's some lighting speed thinking and typing.
Yik
Kudos and Accepted as Solution are welcome!
(2,778 Views)
