USB 6215 AI and A0
it is possible to generate e.g. sinewave at analog output and acquire signal (let say the same as generated) on analog input at the same time or almost the same time? I have an application where sinewave signal is generated from function generator and then signal from my sistem aquired with USB M 6215. But I want now both operation implemented with labview with this DAQ card. Thank you in advance for the tips. First I want to generate on AO in "at the same" time acquire this signal on AI.
(2,881 Views)
Sure, you can do that.  Let us know if you need more help on this.
Yik
Kudos and Accepted as Solution are welcome!
(2,861 Views)
