How do I set simulated values on simulated hardware?
I simulate hardware using the software NI MAX.
I like to access the simulated hardware by using the ANSI C interface.
But I want to get defined values.
How it is possible to adjust simulated values?
(3,864 Views)
Accepted by HerrDengel
You can't. The only value in simulation is the sine wave as explained in the help.
(3,856 Views)
