How do I set the anti-aliasing filter of my NI 6070E ?
Is is set automatically or do I have to set it manually?
(3,226 Views)
If you are referring to the anti-alias filter which sits just behind the board's analog input amplifier, then this cannot be set. This hardware is built onto the board and cannot be configured and/or turned on/off by the user.
Justin Britten
(3,226 Views)
How much the cut off frequency of the filter that built in?
Melhem
(2,738 Views)
As far as I know, the 6070 does not have any anti-aliasing filter. If there was, the information would be in the specs or user manual.
(2,727 Views)
