 etechstan
			etechstan
			10-14-2009 03:37 PM
10-15-2009 05:44 PM
The short input noise level is the amount of noise you will see if you connect the input to ground, so that it should be reading 0V. There are noise and accuracy specifications for the 6225 in the Specifications Document. These are not specifically when the channel has been shorted to ground, but are valid for different ranges of the card.
I do not understand how your question about the noise levels is related to the number of channels on the device. The 6225 has 16 single-ended analog input channels (or 8 differential channels), and all of them have the same specs for noise and accuracy.
I hope this helps you, but if you have more specific questions, please let me know.
-Christina
10-16-2009 08:49 AM
10-16-2009 09:23 AM
 Seth_B.
			Seth_B.
			10-16-2009 09:46 AM - edited 10-16-2009 09:47 AM
It sounds like they didn't actually test the noise on the system, but rather assumed that because one system had a resolution of 16-bits and the other of 12-bits that the 16-bit system would be more accurate. This is generally the case, but not guaranteed. To test this "Short Input Noise Level", my assumption is that you should short the channel to ground and read on that channel, to determine your noise level. For instance, I took a 12-bit C Series module (that was about 4 years out of calibration), shorted Analog Input channel 1 to the ground pin and read data on that line. I got these results, which indicate that, when grounded, I have about ±15 mV of noise on the line. Without more documentation, I can't be certain, but I'm pretty sure that this is what they mean be "Short Input Noise Level".
10-16-2009 09:50 AM
 Seth_B.
			Seth_B.
			10-16-2009 09:57 AM
Do you have a PCI or USB version? And are we concerned about input or output noise level?
If it is input noise level (the amount of noise on a reading taken on a signal input to the DAQ card) then an ocilloscope will not be of assistance. You'll need a precision function generator or a DC power supply. If you are just concerned about the noise on a shorted channel, you won't even need that.
If you are concerned about noise on the analog output lines, then you should connect the oscilloscope to the AO and AO GND channels. For specific pins, I'll need to know if you are using a USB or PCI device. If it's PCI, I'll need to know what terminal block you are using.
10-16-2009 10:03 AM
Seth, Its the PCI version with a filter buffer connected at port 1. You can get an overview of the product at spinematrix.com. I do have an Agilent function generator.
 Seth_B.
			Seth_B.
			10-16-2009 10:14 AM
10-16-2009 10:25 AM
