How to acquire digital data using 6212
  I want to Make weighing Scale Application ,
 I am Using 6212 Multifunction Daq I am connecting to Loadcell(strain gauge) but I unable to get output of the Loadcell  into the  Digital Format.
Minimum Four Load to be connected on the 6212 . Then I want to take the Average and make a raw count
then using different parameter I want to calibrate the system
 so  i can show the truck/Rail wagon  weight in digital format
(3,469 Views)
Explain 'digital format?" Are you trying to acquire strain gauge measurements using a daq card and you do not see any readings?
(3,433 Views)
Digital Format  mean
When the Platform in clear is weight will be ZERO ie it show 0 in indicator ,
When Put Some Weight it show the value like 5 kg.
Simple I want to make weighing scale to measure the Truck Weight ie Tare or Gross
I am using 6212 DAQ
 one Load cell has four wire
+/- EXCITATION
+/- SIGNAL
i WANT TO CONNECT FOUR LOAD CELL IN THE SQUARE FORMAT ONE AT EACH CONNER,
THEN TAKE AVERAGE OF INPUT VOLTAGE .
(3,425 Views)
