Errors when using multifunction DAQ
Hi all,
I'm relatively new to NI and DAQ especially. I'm trying to enable the usage of a multifunction DAQ in one of our programs. As a reference I used the
AIContAcquisition example supplied by NI.
When I run my code I get 2 errors (each time I run it I get one of them):
- Access violation exception was unhandled by user code, Attempted to read or write protected memory (when I call reader.EndReadMultiSample() ).
- Task specified is invalid or does not exist. Also when calling reader.EndReadMultiSample().
I'll appreciate any help or directions.
Noa
(3,297 Views)
what daq device are you using?
(3,275 Views)
The box itself is numbered 1033, the cards are numbered 6281. I hope this helps.
(3,265 Views)
