How to connect 3 phase motor to cRIO or DAQ?
What is the best module to connect a 3 phase motor to a cRIO and how do you connect the motor to the module? We have a typical low voltage wiring for the motor.
(3,658 Views)
Can you post a connection diagram of your motor?
(3,650 Views)
Here is a website with a picture of the wiring for the motor. The one we are using is the low voltage line on the top row. Each of the line endings are marked L1, L2, and L3 from the left to the right.
http://www.metalwebnews.comhowto/ph-conv/fig2.html
(3,642 Views)
