Multifunction DAQ
How to add phase parameter to waveform array in the DaQmx continuous output example?
Hi All,
I am pretty newbie to Labview. I just wanted to know how do I  add phase information to the existing waveform module as shown in the DaQmx Voltage- Continuous output example.
Seee attached, I figured that the the 'Output array' is actually a preset control, is there anyway I may add the phase as an additional parameters to that?
Thank you in advance for any help.
Eric
(4,076 Views)
Accepted by Econg
If you press ctrl+H, the Context Help Window opens and you can hover over the Function Generator VI to see its Inputs/Outputs as well as navigate to its detailed help. As you can see from this screenshot, there is an output for the phase which is separate from the waveform output.
(4,038 Views)
