How to change Resolution of ADC
how can i change the resolution of the analog-digital converter on my NI-USB6211 from 16bit to 12bit ?
This should happen in Matlab. I'm using the Session based interface.
Message 1 of 8
(5,286 Views)
Why would you want to?  I don't see what you would be gaining by doing that.
GCentral
Message 2 of 8
(5,279 Views)
To change resolution, you would need to change the DAQ device to one that has 12 bits. Silly question as far as I can see.
Message 3 of 8
(5,269 Views)
It's because of a Matlab script whitch ran with an older daq pad with a 12 bit resolution.
I have to migrate it to a newer daq pad and had also to rewrite parts of it as i needed a new interface in Matlab (session based interface as legacy based interfaced is no longer supported.
Here is a screenshot of a Voltage measurement. The blue curve is from the new daq pad and looks quite erratic. I think the reason might be the adc.
Maybe you have some ideas
Voltage
Message 4 of 8
(5,236 Views)
This doesn't look like an ADC issue.  It looks more like a noise issue.  What are you trying to measure?  What is your sample rate?  Do you have things properly grounded?
GCentral
Message 5 of 8
(5,221 Views)
I want to measure the voltage of a window motor.
I tried different sample rates, but they all look similar to the screenshot i posted. There the sample rate is 10k S/s.
I hope the everything is properly grounded
Message 6 of 8
(5,218 Views)
Try a smoothing algorithm. You can do it yourself, use a low pass filter, or use Savitsky-Golay smoothing.
If you read the raw binary from the DAQ device, you could manipulate the bits to eliminate the 4 LSB.
Lynn
Message 7 of 8
(5,211 Views)
Accepted by topic author mertin
I got the solution:
Changed the ADC range from -10 V - 10 V to -.0,2 V - 0,2 V
Message 8 of 8
(5,195 Views)
