How to change the default signal connections
Dear Mark,
I followed your advice as follows:
The same error still appears.
How do you think about this ?
Thanks so much for your helps.
Duy
Message 21 of 25
(1,679 Views)
It means that the task you have specified here does not exist:
To check if it exists, right click on the Task constant (the bit circled above) and click Edit NI-DAQmx Task. If it doesn't exist it'll start the process of creating a new task.
Message Edited by macaba on 07-30-2009 04:23 AM
Message 22 of 25
(1,675 Views)
Dear Mark,
I do not think that it is an error about existing. Maybe there are some problems when I set some parameters for DAQmx channel and those configurations are invalid. So, my VI does not work. But so far, I do not know what the error is.
Duy
Message 23 of 25
(1,671 Views)
I have found this knowledge base article which describes the error you are having and a potential fix. Could you try this please?
Message 24 of 25
(1,651 Views)
Dear Mark,
Thank you very for your helps. That document is very helpful to me.
Duy
Message 25 of 25
(1,629 Views)
