How to configure multiple read channels for reading at the same time
I'm attempting to read Multiple channles at the same time in C# using this
            try
                C1Driver.AIChannels.CreateVoltageChannel("CARD_01/ai0", "", AITerminalConfiguration.Differential, -VScale[1], VScale[1], AIVoltageUnits.Volts);
                C2Driver.AIChannels.CreateVoltageChannel("CARD_01/ai1", "", AITerminalConfiguration.Differential, -VScale[2], VScale[2], AIVoltageUnits.Volts);
                C3Driver.AIChannels.CreateVoltageChannel("CARD_01/ai2", "", AITerminalConfiguration.Differential, -VScale[3], VScale[3], AIVoltageUnits.Volts);
                C4Driver.AIChannels.CreateVoltageChannel("CARD_01/ai3", "", AITerminalConfiguration.Differential, -VScale[4], VScale[4], AIVoltageUnits.Volts);
                C1Driver.Timing.ConfigureSampleClock("", Rate[1], SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Count[1]);
                C2Driver.Timing.ConfigureSampleClock("", Rate[2], SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Count[2]);
                C3Driver.Timing.ConfigureSampleClock("", Rate[3], SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Count[3]);
                C4Driver.Timing.ConfigureSampleClock("", Rate[4], SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Count[4]);
                C1Driver.Control(TaskAction.Verify);
                C2Driver.Control(TaskAction.Verify);
                C3Driver.Control(TaskAction.Verify);
                C4Driver.Control(TaskAction.Verify);
                C1AReader = new AnalogMultiChannelReader(C1Driver.Stream);
                C2AReader = new AnalogMultiChannelReader(C2Driver.Stream);
                C3AReader = new AnalogMultiChannelReader(C3Driver.Stream);
                C4AReader = new AnalogMultiChannelReader(C4Driver.Stream);
                V1Data = QST_SetupDAQ.C1AReader.ReadMultiSample(Count[1]);
                V2Data = QST_SetupDAQ.C1AReader.ReadMultiSample(Count[2]);
                V3Data = QST_SetupDAQ.C1AReader.ReadMultiSample(Count[3]);
                V4Data = QST_SetupDAQ.C1AReader.ReadMultiSample(Count[4]);
I'm wondering if this is the best method, or is their a better way to setup the reading of 4 or more channels at the Same time
(5,040 Views)
I don't use c# but I can tell you that you are using too much code and code that will generate an error. You need to create a single task and that means a single CreateVoltageChannel, ConfigureSampleClock, etc. Define multiple channels at once using syntax such as Dev1/ai0:4.
(5,034 Views)
Problem is each Channel need to be controled indivudally as they can be requesting diffrent voltages levels / scales
It's not a problem if I have to configure each channel indivudally, but I do need to know how to have them all start the test at the same time.
Message Edited by RRobertH on 11-24-2009 06:51 PM
(5,029 Views)
As long as you add the channels to a single task you can do it. You cannot configure separate clock rates. If you have a single task and start that, then you do a single read with multiple channels. Sorry, I'm not familiar enough with the c# syntax to tell you what the command for that is. I'm more familiar with LabVIEW and C.
(5,017 Views)
Hello RRobertH,
So there are some limitations with adding multiple channels to one task.  One of these is that they must all operate with the same sample clock settings.  Thus, you would only call  "Timing.ConfigureSampleClock" once for the task.  You can create seperate channels with seperate limits and scales, but they must all use the same timing and triggering.  Additionally, you should use the AnalogMultiChannelReader to retrieve the information for all the channels, then you can parse out each channel.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(5,007 Views)
So just to verify the code would be along these lines then correct ?
try
                Driver.Timing.ConfigureSampleClock("", Rate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Count);
                Reader = new AnalogMultiChannelReader(Driver.Stream);
                VData = Reader.ReadMultiSample(Count);
(4,995 Views)
I'm not exactly familiar with the C# code, but that looks like the proper format.  As long as they are all in the same task, you are fine.
Seth B.
(4,992 Views)
