how to CONNECT DIGITIAL I/O CHANNEL 0 WITH PFI0
I have a USB 6259 with some third part data aquisition software that states "CONNECT DIGITIAL I/O CHANNEL 0 WITH PFI0";
on the front panel under "Didital and Timing I/O" I can see PFI 0/P1.0 , that looks like what is meant by PFIO; but I can't find anything correponding to "Digital I/O channel 0", although it might be the same connector - any thoughts?
Many thanks
Chris French
Neurosciences
University of Melbourne
(3,322 Views)
May be it is asking you to route the digital chan0 to PFI0?
Check in your MAX if you have option to route this channel in Signal routing.
(3,317 Views)
Hi Chris,
You might contact the vendor of the third party software and ask them what they meant.  PFI0 is the same as Port 1, Line 0.
Jim Schwartz
(3,302 Views)
