How to create a named task and assign physical channels to it?
Looking for some help with DAQmx as I am tying myself in knots here.
In a program I wrote a few months ago I used DAQmx Create Task.vi to create a task with a name of my choosing and assign a global virtual channel to that task.
OK, now I want to do exactly the same, but on a system that does not have global virtual channels defined. Instead, I want to assign a physical channel to the task. I tried using DAQmx Create Channel.vi to create a virtual channel from the physical channel, and then call DAQmx Create Task.vi using that virtual channel name, but it won't accept it, presumably because it is not a global channel.
It seems very arbitrary that you can create a named task with a global virtual channel that you have created in MAX, but not a physical channel or virtual channel that you have created programmatically.
The reason I want to define the name of the task is that I am converting my vis to Matlab functions using Math Interface Toolkit, and I want the functions to work without the user having to pass a task name from one to the other. That's what my other program did and it worked very well.
Anyone know how to do this?
(3,651 Views)
Create Channel will create a task if you do not supply it with one.  To add a physical channel to a named task, call Create Task first with your desired name and pass the task output of it into the Create Channel.
(3,647 Views)
In my opinion, what you said works for the AI, but it fails for the AO (at least on my computer) with a Pci-6251 Card
Regards
(3,620 Views)
Thanks guys. I tried what Mark suggested and it works fine. Don't know why I didn't try that particular arrangement.
I am doing single channel waveform output with a PCI-6221. Using Labview 8.5.
(3,616 Views)
