Multifunction DAQ
How to disconnect A PFI line from counter output
I am using a USB-6363 programmed with Labview.
I have a setup that requires me to output a pulse generated from ctr2 on one of four different PFI lines (PFI1, 2, 3, or 4).  In the task setup, I wire the required PFI line to the CO.Pulse.Term property on the ctr2 task.  All of this basically works.
However, the PFI lines remain connected to ctr2 even after I select a new line.  So if I run it once with PFI1 selected, and then the next time I run it and select PFI2, then PFI1 and PFI2 both have the ctr2 output.
What do I have to do to disconnect a PFI line so that this does not happen?
(3,072 Views)
Accepted by topic author dwcarr
You're running into an expected behavior, known as "lazy uncommit". John_P1 discusses it a bit more in this thread:
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(3,060 Views)
Thanks, this was very helpful.  Always a little frustrating when expected behavior and documented behavior do not completely overlap, but I have it working now.  I had to make a dummy digital output task in order to get the desired behavior.
(3,042 Views)
