Multifunction DAQ
How to display multiple channels on multiple plots
I'm using a USB 6009 to capture data on three separate channels. However, the way I have it set up now, I see all three channels on one plot. I'd like to see each channel on a separate plot but I'm not sure how I would do that. Thanks for your help.
(3,518 Views)
You simply need an Index Array function.
(3,508 Views)
Accepted by aparker
Hi Aparker,
Here's a quick picture of what you could do with the Index Array Function to separate your plots onto separate graphs.
(3,500 Views)
That worked. Thanks!
(3,493 Views)
