How to display multiple channels on multiple plots
I'm using a USB 6009 to capture data on three separate channels. However, the way I have it set up now, I see all three channels on one plot. I'd like to see each channel on a separate plot but I'm not sure how I would do that. Thanks for your help.
(3,513 Views)
You simply need an Index Array function.
(3,503 Views)
Accepted by topic author aparker
Hi Aparker,
Here's a quick picture of what you could do with the Index Array Function to separate your plots onto separate graphs.
(3,495 Views)
That worked. Thanks!
(3,488 Views)
