Multifunction DAQ
How to display the wav on a chart or graph if user inputs frequency, amplitude, shape, offset
I have a program (an example program) where the user can input the frequency, amplitude, shape and offset of a wave. How do I take these properties and in the block diagram wire them to display this waveform on the front panel (in a chart or graph)?
Frequency, amplitude and offset is a double. Waveform in in the type waveform function.
code attached.
Please respond. Thanks.
(2,996 Views)
Accepted by Tupaj
To see the actual waveform, you would obviously need an another instrument connected to the output of the Agilent. If you want something simulated and as close as you can, you can wire the waveform function to a case statement and place an approriate waveform generation function inside each case.
edit - You also posted to the wrong board. In the future, remember to post to either the Instrument Control (about Agilent) or LabVIEW (about waveform generation functions) board.
(2,994 Views)
