Multifunction DAQ
How to get ±2.5V AO from NI USB-6009
From the manual of NI USB-6009 DAQ, the analog output is 0-5V.
Can I somehow receive -2.5V to 2.5V analog output? May be to fed -2.5V to the GND of the analog Out to shift the voltage ?
 Thank you.
(3,993 Views)
Accepted by DenisGl
H, Dennis,
I am afraid, you can do it only with an external circuit
as I see, the minimum components are:
-two dual-supply rail-to-rail op-amps
-a 2.500V  voltage reference
-a negative supply of -5V (e.g a small +5V/-5V DC/DC converter, ICL7660)
-five precision resistors
Pros
(3,978 Views)
Yeah...I thought so.
Thank you.
(3,945 Views)
