How to get +5V from the +5V Power Source on USB-6501
The +5V power source output on my USB-6501 is reading 4.74V and not the +5V I would like. I know the reason can be the
USB power supply but is there a method of getting +5V despite this lower voltage. Thank you.
Newbie16
Message 1 of 8
(5,100 Views)
That's what the spec is telling you:
The voltage source provided by the USB host. The voltage
is nominally 5 V, but varies from system to system.
Easiest way to go would be an additional 5V supply (Check and use a second USB 5V on your PC?)
Next would be a DC-DC converter.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 8
(5,073 Views)
Yes I have looked at a DC-DC converter, something like the one below. Hopefully it will do the job, thanks.
http://radionics.rs-online.com/web/p/isolated-dc-dc-converters/4735340/?searchTerm=473-5340&relevanc...
Message 3 of 8
(5,069 Views)
The question is : Why can't you use the 4.75V and need 5V?
AND
The spec of the DC-DC converter tells about a 0.1V ripple ...  will you be happy with that?
Henrik
LV since v3.1
Message 4 of 8
(5,068 Views)
I'm running the 5V (or 4.75V) into a MAX680 +5 to +/-10V IC to power an op amp that needs to output +/- 10V for a motor controller signal. If I can't
reach 10V I cannot get max. speed from the motor, at the moment, as you can guess, I can only get +/- 9.4-9.5V so trying to work out the cheapest
alternative (project objective is low cost, minimal parts)
Thanks for checking the spec, I will have to check out the effect of the ripple, I might get the DC-DC converter, I have not
used one before so would be interesting to test.
Message 5 of 8
(5,063 Views)
I would just get on Digikey and search for a power supply that can do +/-10V.  Then it is independant of the USB.  They are usually pretty cheap.
Message 6 of 8
(5,060 Views)
better be a +-12V supply giving you some headroom for an output OP and kick out the MAX680 😉 (but we have DIO only!!! )
Again: What do really need? And what do you have?
  Just a full power on for the motor control?  That can be done with two DIO, opto couplers and (the usually provided) +-10V of the motor controller 😄
One DO for power, one for direction!!
Henrik
LV since v3.1
Message 7 of 8
(5,053 Views)
Hi Newbie16,
Another option would be to use an externally powered usb hub with a more reliable voltage supply than your pc/laptop can supply.
The best thing as others have mentioned would be a dedicated supply suited towards the motor you have in mind.
Message 8 of 8
(4,990 Views)
