usb-to-isa documentation
does anyone have documentation (datasheet or manual) for the National Instruments USB-to-ISA adapter? part number 184306B-01.
thanks!
Message 1 of 10
(5,829 Views)
I believe that was an internal part for some of our preliminary USB devices. It was never offered by itself (unless someone corrects me). You would have to use it as part of the original hardware set it was sold as. Should have been a DAQ or DMM device of some kind. Smiley Happy
Message 2 of 10
(5,824 Views)
is there any way for you (or someone) to find out what it was originally installed in?
Message 3 of 10
(5,819 Views)
Reichenbach,
That is an internal part to some of National Instruments’ devices that were made as early as 1997 – 1998, and was used through the mid 2000’s; these devices were typically DAQ and computer-based instruments as gaving mentioned.  What are you looking for?
Wayne T. | Application Engineer | National Instruments
Message 4 of 10
(5,788 Views)
we found it amugst our parts and are trying to identify it. we have a TON of NI equipment in our lab and do not have time to open them all up to determine what it goes to. Nor to we want to recycle it. We'd like to identify it and catalog/store it with that information.
can i give you a serial number and have you figure it from there?
S/N C1DE0D
P/N 184306B-01
thanks!
Message 5 of 10
(5,786 Views)
reichenbach,
That puts me closer, but still short, to identifying the card.  This serial number is one of many, but won’t tell me what the board is.  Do you see other serial numbers, CCA (Circuit Card Assembly), etc.?
Message 6 of 10
(5,779 Views)
No CCA but I have additional part numbers:
184308B-01
11VRM 891000577
Message 7 of 10
(5,773 Views)
reichenbach,
PN 184308B-01 is a USB-to-PCI adapter, and doesn’t further identify the product. The other part you listed is another child part. If you prefer getting this accomplished sooner, may I recommend calling our Technical Representatives. If you have the product in front of you, and you have someone on the line, this may be resolved faster. Their number is 800-433-3488, and give your zip code when asked. I’m personally monitoring your post here so if you prefer this route, that’s okay, too.
Message 8 of 10
(5,770 Views)
reichenbach,
Were you able to get this item identified yesterday?  If not, you can provide another part number or serial number for me to research.  I will be watching this thread again today.
Message 9 of 10
(5,753 Views)
i was hoping to get the model of what this would have been installed. im just going to put it on the shelf and hopefully figure it out down the road.
thanks for you help
Message 10 of 10
(5,747 Views)
