How to get the highest internal base clock using c++?
I would like to get the highest internal base clock supported by a DAQ card, for example, 80MHz for PCI-6251, 100MHz for PCIe6361. What function should I use? I have tried DAQmxGetSampClkTimebaseRate and DAQmxGetCICtrTimebaseSrc, but they both return default value, which is 20MHz.
(3,323 Views)
int32 __CFUNC DAQmxGetDevCIMaxTimebase(const char device[], float64 *data);
(3,304 Views)
It works. Thanks.
(3,300 Views)
