compactDAQ sample rate question...
Ok, I think I have this question in the right place, but if not I beg forgiveness.  🙂
I have a CompactDAQ  (4slot) with just a 9225, and 9239 modules installed.  I ran the DAQ assistant and have all seven channels being read and being written to a text file from a event structure... when I push the button, it logs data.  Pretty simple really, also I have a "Wait" timer setup with a 50mS wait time, so I'm basically updateing my loop 20 times per second, not that fast.  The odd thing is that my DAQ module is only giving me data once per sec.  Did I set something up wrong?  Seems to me that as the loop updates it should resend the "True" from the button to the event structure and data should show up at a rate of about 20 samples /sec.   Sample VI attached.
Hints and points in the right direction are greatly appreciated!
Chad
(4,409 Views)
I'm unable to open your vi due to using an earlier version, but have you checked the timeout duration for the event structure?  Perhaps that is your mysterious 1 sec?
(4,407 Views)
Sorry, I misspoke!  It's in a case structure, not an event structure!
(4,402 Views)
Accepted by topic author chuggins143
Hi chuggins143,
The behavior is coming from your settings inside the DAQ Assistant:
If you want the loop to run 20x per second, then "Samples to Read" should be 1/20 of the Sample Rate.  DAQmx will block until "Samples to Read" samples have become available, so this is what is slowing down your loop.  You also might want to change the Timing Settings to "Continuous" if you want to avoid gaps in your data.
Best Regards,
John Passiak
(4,391 Views)
Perfect!  Thank you very much!
C
(4,358 Views)
