How to install a PCI NI-DAQ on an ETS target?
I’m painfully ignorant on how I can go about to install a PCI-6024E DAQ on my real time desktop PC target.
I’m using Labview 8.2. I have connected my real time PC with my developer PC via a crossed network cable and there after installed the LV real-time module on my RT desktop PC.
I’m guessing that I should install the driver for the PCI-6024E on my RT desktop PC, but I don’t know where to find this driver and how to go about thereafter. I would be great full for any advice that I could get here.
(3,352 Views)
Möheb,
installing a RT System is done completely from the host system. So you need to have all softwarecomponents installed on the host.
In your case, you need NI-DAQmx installed on the host before installing it to the RT. The installation on the RT is done with MAX by rightclick on the system and choose "add or remove software". Just select the needed drivers (do not forget NI VISA if it is not already installed!) and go on. Now the device 6024 should appear in MAX in the RT system....
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,347 Views)
Thanks a lot!
I apparatley had missed to install NI-DAQmx first time around. It's not part of the defauelt installation which is good to know.
(3,310 Views)
