test panel disable for 4070
I have a new 4070 board, MAX can recognize it and selftest ok, but test panel button is disable. the driver is DAQ8.1 and DMM2.5
I can use SFP to control 4070 but the DMM vis in sample folder and pallet vis all show me an error"Device is not supported by the driver".
I have another set of hardware which have been installed 2 years ago, on DAQ7.2 and DMM2.2.1.
So the old VIs can not be start so far.
*The best Chinese farmer*
(3,031 Views)
It is a expected behavior that Test Panel for DMM is gray out. The NI-DMM 1.6 driver accessed the test panel from the Traditional NI-DAQ (Legacy) driver for devices listed in Measurement and Automation Explorer. However, NI-DMM 2.0 added devices supported only through the NI-DAQmx driver which could not use this original NI-DMM test panel.
For your second problem, I think you may uninstall two version NI-DMM driver and reinstall the newer driver.
(3,021 Views)
