07-11-2005 10:47 AM - edited 07-11-2005 10:47 AM
Message Edited by kuroshio on 07-11-2005 10:49 AM
Message Edited by kuroshio on 07-11-2005 10:55 AM
07-12-2005 05:39 PM
Hello kuroshio,
Current measurements are really just a voltage measurement with V=I*R applied. Have you tried first measuring a voltage and comparing that to the voltage from your voltmeter? You could measure the voltage a couple of ways. I would suggest first using the Measurement & Automation Explorer (MAX) test panels. Make sure your signal is connected to the correct pins and choose differential as the terminal configuration. Once you have a correct voltage measurement, then you can use a LabVIEW example from the example finder (Help>>Find Examples) to get started with a current measurement. In the example finder, you can navigate to Hardware Input and Output>>DAQmx>>Analog Measurements>>Current. There are a couple examples there for current measurements. You will have to enter the value of the resistor you are measuring the current through. Be sure to re-post if you still have problems:)
-Alan A.
09-07-2005 12:03 PM
09-07-2005 12:18 PM
