How to open the .llb file?
I have tried to open the .llb file in the following page
NI Developer Zone > Development Library > Analysis and Signal Processing > Signal Processing > Advanced
But I cannot open the Accel to Vel& Disp.llb.
I used LabVIEW player.Which SOFTWARE do I need to use?
Nyan
(2,623 Views)
Hello;
Some VIs are not compatible with Labview Player, meaning you need to have a copy of Labview to access those. That is probably the case with the VIs you are trying to access.
Regards
Filipe A.
(2,623 Views)
