How to read 3 Analog Inputs simultaneously with 6070E?
I wanted to read 3 analog signals simultaneously using NI PXI-6070E DAQ card and Labview 2010.
I can successfully read and record 1 signal (which you can see in the attachment), but don't know and can't find any examples on how to read 3 signals simultaneously. Any help, especially a simple example would be great.
Thanks!
(3,125 Views)
Accepted by sdavoudi
Just click on the pull=down of the physical channel constant, select Browse, and Shift-Click or Ctl-Click to add the other channels. You can also type in the new channels with the syntax ai0:2 for three continuous channels as an example.
(3,118 Views)
Ok, wow! That was much easier than I expected!!! Thank you so much...
(3,114 Views)
