Multifunction DAQ
How to read two different analogic signal with differential and RSE input terminal configuration with PCI-6221?
I have an accelerometer that I want to read his signal in differential input terminal configuration. I have anothers sensors that I want to read in RSE input terminal configuration.
Is possible to simultaniusly reading these two signal with different input terminal configuration?
The accelerometer is connected to pin [AI 13 (AI 5-); AI 5 (AI 5+)]
The others sensors are connected to pin: AI 0, AI 1,  AI 8 and AIGnd
I can´t do with this code. You could find attached the pin out drawing, the code file and a code picture.
Labview 15.0
PCI-6221
Block contact D-sub 37 pin
Any help please?
 Thanks in advance.
(1,525 Views)
Accepted by Frochoso
DAQmx Task with Multiple Terminal Configurations
https://tmesystems.net/
(1,505 Views)
Thanks a lot. This is the topic that i needed.
(1,468 Views)
