Multifunction DAQ
How to run two PCI-6143 devices
I want a description how to setup DAQmx to run with two PCI-6143 devices synchronously.
Please give a description using DAQmx C++ API. e.g. DAQmxCreateTask.
I guss that it will begin with:
1. Attach a RTSI cable between the two devices.
P.S. Specifying this cable can be made in MAX, is it possible from the API to see if such a connection is/was defined in MAX?
-cpede
(3,614 Views)
I found some links for you:
Regards
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,600 Views)
Hi cpede-
Dennis' suggestions all center around the Traditional (Legacy) NI-DAQ driver.  The 6143 is only supported by NI-DAQmx and all new development should be done in NI-DAQmx, so please disregard those suggestions.  I noticed that you're using NI-DAQmx 8.3, so I thought I would point out that it is MUCH easier to synchronize two S Series boards using NI-DAQmx.
The steps are as follow:
  1. Physically connect a RTSI cable between the devices.
  2. In MAX, right-click on My System>>Devices and Interfaces and create a new NI-DAQmx RTSI cable device.
  3. Right-click on the RTSI cable and associate both devices with the RTSI cable.
After this, you're basically done with configuration.  The driver now knows that a RTSI cable is present, and you can take advantage of the multi-device task feature added for S Series in NI-DAQmx 8.3.  Open any buffered analog input shipping example ( for example, \Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Cont Acq-Int Clk ).  You only need to specify the physical channels to use in the DAQmxCreateAIVoltageChan()as "DevX/ai0:n, DevY/ai0:m" where X and Y are your device numbers.
Hopefully this helps-
Tom W
(3,586 Views)
That sounds great Smiley Very Happy
Does this apply to only devices of the same type/series, or can I mix devices e.g. PCI-6143 and PCI-6040E? - Or is it just much easier with the same board types?
Can I detect using DAQmx that the RTSI cable is configured in MAX, that would be very convenient?
-cpede
(3,575 Views)
HI cpede-
No- multi-device tasks ONLY work for S Series and DSA devices.  In order to synchronize E Series, M Series, or other MIO boards you will still need to connect and configure your RTSI cable and then follow the programming example shown in \Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Synchronization\Multi-Device\Continuous AI
There is currently no way to query NI-DAQmx to determine if a RTSI cable is configured in MAX, but this definitely sounds like a useful feature.  Please file a product suggestion if you would like this functionality considered for future versions of the driver.
Thanks-
Tom W
(3,560 Views)
