Multifunction DAQ
How to send data from usb 6009 to a RS232 port ???
Hi everyone,
The converter I intend to control has a RS232 port (terminals 71 and 72 as specified in the diagram; RXD and TXD) and using this I can set and read parameters and issue control commands. I wish to use the DAQ USB 6009 for this purpose. The data format will be as follows: -
One start bit - logical 0
Eight data bits
One stop bit - logical 1
There are only 3 acceptable baud rates that are 300, 600 and 1200 since the converter is very old.
This is doing my head in completely as I cannot think of a solution. Can this be done by the USB 6009 DAQ card ???
Any help will be appreciated
Sandeep
(4,093 Views)
Accepted by Sandeep_k
If you want to control the converter via RS232 commands you should use a RS232 device. If your PC doesn't have a (free) COM port you can use a cheap USB2RS232 converter. The driver that come with it will provide a COM port to the OS-system and with the NI-VISA driver you can use it in LabVIEW. Maybe there is already a LV-driver for your controller, just check the NI-Web driver network.
 You will need a custom cable with at least three wires from the COM port (usually a DB9 connector) to the converter. GND (DB)-PIN5 to 55, PIN 2 to 71,  PIN 3 to 72  (maybe you have to swap 71 and 72 if you can't get a connection, more details should be in the converter manual).
You can start with hyperterminal for a first check or use the RS232 - simple write and read vi found in the LabVIEW-help- find examples section (don't forget the termination character here 😉
Greetings from Germany
Henrik
LV since v3.1
(4,088 Views)
Thanks Henrik, you are bloody awesome.
Few questions though,
1. So basically, I wont need the DAQ to control this converter ???? I can use NI-VISA as the interface between LabVIEW and the converter, I assume ?? I have never used VISA before but I am willing to learn.
2. What is this LV driver that you mentioned ? I checked the NI web driver network but no luck :(. The converter I am using is dinosaur, probably about 8-10 years old.
3. The connection procedure you've mentioned looks good and hopefully it works as there is no connection procedure given with the converter manual.
Thanks once for helping out. I am marking your above post as solution as it looks good. 🙂
Sandeep
(4,071 Views)
Yepp 🙂
2. What is this LV driver that you mentioned ?I checked the NI web driver network but no luck :(. The converter I am using is dinosaur, probably about 8-10 years old.
Just because it is old, there had been a good chance that someone else already has written/drawn some LabVIEW code for it. Search the web for '$convertername +LabVIEW ' and ask for it in the LabVIEW forum
Sandeep
Henrik
LV since v3.1
(4,052 Views)
