04-17-2008 12:04 PM
04-22-2008 11:03 AM
To set the data transfer mechanism, please look to the NI-DAQmx C Reference Help. The topic titled "Get/Set/Reset AO_DataXferMech" is helpful and has a link for the values for the last parameter of the function. As far as examples, I do not believe there are any examples specific to changing data transfer mechanism. However, here are two KnowledgeBases that should help. One states to set the data transfer mechanism after the timing call to avoid an error.
KnowledgeBase 2W8CH8HT: Error -200172 When Changing the Data Transfer Mechanism
I am curious to know if you are interating any DAQmx function calls other than DAQmx Read or Writes. This might be why your processor is railing.
