How to set up an analog edge trigger to start multiple channel acquisition
Hello there,
I'm trying to set up an analog edge trigger... with very poor results so far. The DAQ i'm using, NI USB 6008, doesn't support hardware analog triggering, so i have to build a VI to do that. I'm logging 6 MEMS accelerometer (voltage signal), for my application i would need to start acquiring data when the first of the six accelerometers (the closest to the source of excitation (impact)) gives a signal over a certain threshold (edge). It might seem a fairly easy to implement, but i'm a beginner with LAbView and it is driving me crazy! please help!
find attached a copy of my VI.
(3,020 Views)
Hi Babidi,
You might instead try starting with this example:
Continuous Acquisition with a Software Analog Start Trigger
It's a bit more complicated than using the blue Express VIs, but it should work out of the box for a single channel.  It sounds like you know which sensor is going to be high first so this should be suitable; if not you could always modify the code to check for all 6 channels.
You'll need to add logging yourself since this example only plots the waveform on the front panel.
Best Regards,
John Passiak
(3,010 Views)
