measurement every nth trigger using NI PXI 6251
I have a NI PXI 6251 DAQ card. Is it possible to configure a system which measures (AI0) every nth trigger?
What i have is, i have a signal from an encoder, which sends digital pulse every 0.1um step. What i would like to do is measure every 1um which means i have to measure(1Mhz sampling rate) every 10th pulse of the encoder. Any idea on how i can do that with the PXI 6251? Im thinking of using a counter probably?
(3,362 Views)
Hi Carlo,
You're absolutely on the right track with your idea to use a counter.  This example will use a counter to divide-down the external signal (it shows a divide-by-2 but you can change this parameter to 10).
You can then use the Internal Output of the counter as the AI Sample Clock.
Best Regards,
John Passiak
(3,344 Views)
Hi John,
This is very helpfull. 🙂
Thank you very much!
Best Regards,
Carlo
(3,338 Views)
