How to start a timer in labview when a signal crosses a threshold voltage
Hi Bill,
Try the attached code--it uses hardware timing and averages N points together (I'm assuming you're looking to reduce the effect of noise on the measurement).  Your loop rate is going to be (Sample Rate / N)
Edit:  Don't use the default value of -1 for "Samples to Average".
Best Regards,
John
Message Edited by John P on 05-03-2010 12:32 PM
John Passiak
Message 11 of 11
(1,517 Views)
