How to switch between channels?
I have 16 signals to monitor, but my DAQ card can only handle 8 differential channels. I only need to record one set of data every 10 minutes, and all the 16 signals don't have to be recorded at the same time.
Is there any hardware (like a switch box) that I can use to do this? Can I control this switch box in the Labview (not manually flip the switch)?
Thanks.
(3,407 Views)
There are a number of relay boards that will do this (although slowly). It sounds like "slowly" is OK. Look up the ER-8/ ER-16.
(3,404 Views)
Thanks. Is ER-8/16  for digital or analog signals? I have analog signals as input.
Message Edited by J3000 on 04-26-2007 08:09 PM
(3,390 Views)
National Instruments offer a wide variety of switching solutions in the PXI form factor:
https://www.ni.com/en-us/shop/category/switches.html
These include Multiplexer switches that will be perfect for you application. These can also be controlled using the NI-SWITCH driver in LabVIEW.
Alternatively you can purchase an SCXI chassis with an 1100 or 1102 that can increase your DAQ card's channel count upto 32 channels.
Hope this helps!
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,376 Views)
