Multifunction DAQ
How to synchronize NI-9219 with other modules
Hi, i need help with this:
As you can see in the image, I have already synchronized NI-9361 with NI-9237 (I am not sure this is correct but i am getting synchronized reading in the tdms file), and I want to synchronize NI-9219 module with these two modules. I have tried the same method which I used to sync NI-9361 but it's not working. Can anyone help me with how to synchronize three devices simultaneously?
Kumaresan
(927 Views)
Accepted by Kumaresan.mech
As long as all the modules are in the same cDAQ chassis, you can use Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
https://tmesystems.net/
(900 Views)
Thanks for the information.
Kumaresan
(860 Views)
