How to use an external clock to acquire analog data?
I need to acquire dta using an external clock which has a variable frequency (in a small range). I am using a PCMCIA 6062 board. Does it accept external clok?
(2,570 Views)
The 6062 can acquire data based on an external clock. If you are programming in LabVIEW, take a look at the shipping example called Cont Acq&Graph ExtScanClk.vi. If you are using C or VB, there are examples in the NI-DAQ/Examples folder.
Brent Runnels
(2,570 Views)
