How to wire self-powered current transmitter to 9207 analog input?
I am also trying to do a similar thing but in my case I have 2 relative humidity transmiters with a 4-20mA + and a 4-20mA- and they are powered externally. If I connect the 4-20mA + to AI8 do I have just to connect the 4-20mA- to COM?
Any guideline will be appreciated!
Message 11 of 15
(1,744 Views)
Hello suf13,
Yes, that is the correct way to connect the current inputs.
Patrick W.
Message 12 of 15
(1,725 Views)
I have attached the drawing depicting how I am planning to wire my Analog Input card.  I am waiting on parts for the panel, so it is not actually wired yet, but this is the method I chose to try.
Message 13 of 15
(1,723 Views)
Hello wishiwasanindian,
It looks like you are using -24V as your common ground.  I would be very cautious of doing this, because the 9207 Maximum working voltage for analog inputs is between +-10.2 V of common ground.  So, this will only be an acceptable common ground if you are expecting to read in voltages between about -34 V and 14 V.
Patrick W.
Message 14 of 15
(1,709 Views)
No, my common ground is at earth ground potential.  It is just poor nomenaclature on my part, I labeled 24- as the return path for the 24VDC power supply.  It is not -24V, but the 24 - connection to the power supply.
Message 15 of 15
(1,707 Views)
