Multifunction DAQ
Hysteresis
I am trying to figure out how to build this on labview.
Create a system that:
  • If the heater is already ON (shift register) turns it OFF when room temp reaches Setpoint + Hysteresis
  • If the heater is already OFF (shift register) turns it ON when room temp reaches Setpoint - Hysteresis
(922 Views)
This is a homework assignment, right?   How much farther have you gotten?
Maybe it'll help to talk through your thought process here so someone can give you useful hints or nudges in the right direction.
-Kevin P
(856 Views)
